Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Brakes and Suspension
Old 06-11-2010, 10:00 AM
drakered6 drakered6 is offline
Question coil over kits vs spring and strut
Whats the difference between a coil over kit and just buying struts and springs? Im new to those parts so i have no idea. Any help would be great. Also, which would be best to use?
Old 06-11-2010, 12:36 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: coil over kits vs spring and strut
Struts/Springs are sometimes have adjustable dampening, but usually not too much. My boys IS300 has Tokoyos on them and are 5-way adjustable with a 1.5"-1.75" drop. I have coilovers, and they're 32-way adjustable, 0"-4" drop, and can adjust spring rate. Spring/shocks are great if you get good sets, and usually have a decent price to them. Coilovers are more race-ready, and cost a lot of money.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 06-11-2010, 12:50 PM
so if i were to buy coil overs would i have to buy struts also or anything else?
Old 06-11-2010, 01:04 PM
LandoAWD LandoAWD is offline
Send a message via AIM to LandoAWD
Depends. Coilover sleeves require struts, which you have to modify. Coilover kits come complete, but cost BIG $$$ for a proper (matched, dyno'd, etc) set. The budget coilovers you'll come across (800-1k) are generally acceptable for street duty, but don't see the same QC as the high end kits and DIY kits.
Kris
2012 Genesis Coupe 2.0t
Old 06-11-2010, 10:04 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Stock struts are not meant to be operated at ride heights other than stock. If you use stock struts with any lowering springs they will blow out relatively quick so its not recommended.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
