| F Series Forum covers questions and discussions regarding Ford F-150, Ford F-250, Ford F-350, Ford F-450, Ford F-550, Ford F-650, and Ford F-750. |
2005 F-150 runs rough after changing battery.
About a month ago I replaced the battery in my truck. When I reconnected everything the truck was running rough. I have experienced this before with other vehicles and understand that the computer need to reprogram itself but it has been over a month now and I have put over 2000 miles of varied driving on the truck so I'd expect it to be gone by now.
The idle is just a bit rough and the truck runs fine but it is definately worse than before I changed the battery. The truck will occasionally stall when put in reverse which it never did before. The truck is a 2005 with about 80,000 miles and has run perfect up until now. Someone suggested I change the MAF so I did and the was no change. Any other suggestions? Thanks |
Re: 2005 F-150 runs rough after changing battery.
have someone hook a scan tool up and reset the KAM the keep alive memory holds old info for a long time your truck might not remeber the right base fuel trim anymore and cant adjust restting the KAM will put values back to zero and it may relearn better
clean the idle aircontrol and then try and restart. then unplug coolant temp sensor and see if it starts. toivo
