Old 06-10-2010, 04:03 PM
lesabrefan lesabrefan is offline
2001 Lesabre won't start - please help
At first the remote control stopped working, I thought it was the battery. Then I could not open the trunk from the inside of the car. When I tried to start the engine, nothing happened at all. No lights, no noise, the engine did not turn over. The battery is 1 or 1.5 years old. From reading the web it does not seem like it's the battery.
Thanks in advance
1996 Lumina 3.1 - 191K
2001 LeSabre Custom - 153K
2006 Explorer 4.0 - 55K
Old 06-10-2010, 05:53 PM
Re: 2001 Lesabre won't start - please help
Here's a crazy update. Started to jump the car. The jumper cables are connected and the assisting car is running. Tried my remote on the Buick - it worked. Put the key into ignition and turned. At first got a couple of clicks/grunts. Tried one more time - gray smoke started to come up from the engine, on the left hand side between the coolant tank and the engine. Then there was a pop and I obviously stopped trying
What is going on?
Thanks
Old 06-10-2010, 07:34 PM
maxwedge maxwedge is offline
A990 racer
Any leaks?, it may just have popped back from low voltage, leave the jumpers on for 5 minutes, try it again. Not much we can see or do from here.
Old 06-10-2010, 08:16 PM
maxwedge, there are no leaks, nothing visibly burned. Retried jumping/jumpering. Now the remote does not work during the hookup and turning the key does not do anything. So it seems like something did go
If nothing comes to mind, I guess it's a tow to the mechanic?
Old 06-10-2010, 10:01 PM
inafogg inafogg is offline
fuses???
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
Old 06-11-2010, 08:30 AM
Originally Posted by inafogg View Post
fuses???
I opened up the fusebox under the hood. Looks as clean as it can be - nothing burned, nothing melted.
Old 06-11-2010, 03:16 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Even though the battery is fairly new, that does not mean it is good. You need to have the battery load tested to verify condition. All indications point to a dead cell in the battery.
Old 06-11-2010, 07:44 PM
HotZ28, thanks! You got my hopes up. Going to get a new battery tomorrow.
Old 06-11-2010, 09:35 PM
HotZ28's Avatar
AF Moderator Elite
Let's hope the engine it is not hydrolocked!
Old 06-22-2010, 12:07 PM
HotZ28, it was simply a bad battery. Advanced Auto replaced it since it was only a 16 months old. Thanks for your help guys.
P.S. Good lesson for me too, a "new" battery can die too.
