Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 06-10-2010, 03:32 PM
atherts atherts is offline
Question ac/ heat venting
I am helping a buddy work on a 2001 dodge ram 1500. The problem is that the ac and heat will only blow at your feet? Any ideas?
Old 06-10-2010, 04:13 PM
jdl jdl is offline
Re: ac/ heat venting
I'd want to check actuators, directional doors. They should be vacuum operated. I'd want to check vacuum at each setting, floor--defrost--dash, whatever.
Old 06-12-2010, 06:03 AM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
I agree with jdl, sounds like you're lost vacuum.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 06-15-2010, 02:17 PM
Where is the actuators and doors located under the dash?? Do I have to take the whole dash off?
Old 06-17-2010, 06:40 AM
AF - Advisor
From one pal to another...a free service manual and it's good.
http://pdftown.com/Dodge-Ram-2001-Service-Manual.html
Old 06-17-2010, 07:53 AM
Talking Re: ac/ heat venting
Thank you
Old 09-18-2010, 12:45 AM
gilbert.b gilbert.b is offline
I had this same problem on my 99, under the dash behind the cup holder, and behind the air-bag switch, is a blend door. and the rod fell off of mine,
kind of hard to get your hands in there but not a hard fix, just snap it back on. hope that takes care of it for you.
Old 09-18-2010, 07:13 PM
AF - Advisor
Thanks for the info!
