Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 06-09-2010, 08:03 PM
Ram1970 Ram1970 is offline
Need help ASAP
I am trying to remove and replace the universal type joint behind the front wheel hub. The joint wont compress a bit. Tried PB blaster, then C-clamp with breaker bar until the clamp was flexing really bad. hammered a bit as well. Any suggestions?
1997 Dodge Ram 1500 4WD 5.2L
Old 06-12-2010, 08:23 AM
Re: Need help ASAP
Well, I got it done finally. It wouldnt press out at all. Broke two heavy duty C-clamps in the process of trying. Wouldnt move even a little that way. What worked was pure anger and a hammer. That usually works when all else fails. Anyway, thanks for the help guys.
Old 06-12-2010, 09:25 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: Need help ASAP
Glad you worked it out Ram1970,
I haven't done one yet and was hoping someone who knew would post....doesn't look like something to look forward to.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
