How to check "air ride" suspension - looking to buy used Town Car
Hello,
I am looking to purchase a mid 90s Town Car, I know that the air ride suspension is a known issue and can be expensive to fix. Are there any early warning signs? Any other known issues to watch out for? Thanks!!! |
Re: How to check "air ride" suspension - looking to buy used Town Car
Converting from ARS to Reliable Coil Springs
2004 Signature Series, 223k, Current Client Getter 2002 BMW 325Ci Convertible, 132k, Current Grocery Getter 2008 Toyota Tacoma TRD, 82k, Current Hauler 1996 Cartier, 173k, Traded in For The 2004 Signature 1990 Signature, 157k (sold) 1990 Signature 6-Passenger Limousine, 87k (sold) |
Never never never convert. air suspension is the best suspension for the town car. i converted once before, and hated the idea. the suspension is not that difficult to fix if something goes wrong. here is a tech tip that works out greatly if anything goes wrong, Use this tech tip http://www.lincolnsonline.com/tech/00061.html.
And before you chime in and say the ride quality is diminished, well, that just isn't true do any degree. The ride is actually a little better as Coil Springs provide a level of side-to-side stiffness that an Air Spring does not.
If I had a car with ARS installed, I wouldn't change to coils. I enjoy it on my dad's '99 HPP Crown Vic over my poverty coils. And coils can begin to sag over time, so they don't last forever either. But like said above, coils are significantly cheaper. I have seen a coil fail, but only once - and it was due to improper installation. And coils don't offer any better side-to-side stability. If you ever took out the rear control arms, you'd see that the axle will move pretty freely side-to-side. I was able to move mine several inches side to side (with coils, not RAS) with little force when installing my new rear control arms.
![]() 2000 Mercury Grand Marquis LS - 119k / 14.89s @ 92.11MPH [ pictures | videos ] > Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok > Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB > BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms > CVPI aluminum driveshaft |
The ARS is still limited in the side-to-side motion since the ARS is similar to a piston in a cylinder. The piston is bound by the sidewalls of the unit. They can move side-to-side but no more than coils. Besides, coils or ARS, other suspension components should be taking care of the side-to-side movement. Watts linkage, sway bar, control arms, etc. After installing my 17mm sway bar from a CVPI, my rear end no longer does that side-slip when I hit bumps and potholes.
Civilian CVs and GMs and I believe TCs did not come with rear sway bars - and mine was practically sideways in the turns. Those that had the HPP package, had a 28mm front and 21mm rear. I think newer models might all come with some sort of rear sway bars, but I never bothered to look.
I got the 17m from a local guy who had it sitting in his garage from a CVPI that upgraded. It fit right up into the car. I just had to get the axle brackets, bolts, and speed nuts (FoMoCo), poly bushings (ENS), and end links w/ poly bushings (MOOG). Even though it's only 17mm, it lets the watts linkage do it's job so much better and ties the wheels together enough to reduce quite a bit of sway (over no bar). And if I go 21mm, I'd have to upgrade the front bar as well unless I want a bunch of oversteer. Right now it's perfect. Took about 15 minutes to install once I got it up on jacks. Total price was about $40. You can get a new 21mm rear bar from the dealership, with the end links and rubber bushings for about $30.
![]() 2000 Mercury Grand Marquis LS - 119k / 14.89s @ 92.11MPH [ pictures | videos ] > Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok > Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB > BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms > CVPI aluminum driveshaft Last edited by Blue)(Fusion; 07-22-2010 at 01:09 PM. |
The RAS is not that not that difficult of a system when you understand the mechanics of it. You have a compressor, dyer, and vent solenoid all in one. You have two rear air bags with air solenoids atop of them. You have one air line that runs from the front of the car to a "T" fitting. The air lines from the "T" fitting goes into the two air solenoids on the bag. Finally you have a control module that controls everything. There are simple test that can be performed to test the system. The ride quality is completely changed when you convert. When I converted it was one of the last things I wish I would have done.
You may ask, why did I convert in the first place. Lack of knowledge of the system. Just recently I had a failure with my RAS. My first issue was figuring out why my car was not lifting on the driver side. Come to find out in the installation of some rear shocks, the mechanic torched my air lines. I went to the junkyard to get some air lines ($25) off a junk car, and I replaced those lines. Now my other issue was trying to figure out why my car was throwing on the "CAS" light, and the car was not venting. I ran test after test, and purchased a new air spring solenoid ($15) and control module ($25). Here is the lack of knowledge of the system. When i removed the air compressor from the car and ran power directly to the vent solenoid (this vents air out of the system), my car would vent. So I knew it was not the compressor or the control module. The vent solenoid runs power all the time, and the control module grounds the system. I was losing ground to my vent solenoid, and found out I had bad wiring from the control module to the vent solenoid. I ran a direct ground from the control module connector to the vent solenoid, and now my system is back to running perfectly. I know many people would say, see this is a prime example on why to convert to coil springs. My position against that is, I am constantly traveling with a heavy load. The springs could not hold my load the way the RAS does. When you understand how something works, you have a better understanding on the signaficances of it. DON'T CONVERT. |
I have converted to Coil Springs and my '96 Cartier still floats down the road like it was designed.
Sorry yes there is a height sensor on the rear of the car that sends information to the control module to let it know it has reached trim height.
Is that with more than three people and baggage? I am pretty sure that car does not float the same way. You know what, I am sure that it does not. But hey if that is whay you like so be it. I like for my cars to be orginial the way the car was designed. Millions of dollars in research and development have discovered the RAS is the best for the car. I will stick to their assumptions. |
And if Air Ride was so great it would be standard equipment on all cars, just as ABS, Power Windows and SRS's have become.
It's a user preference. Yes there's more that can go wrong, but it has it's advantages or else it would not exist.
I hardly call it an advantage. Only an engineer can take one part and turn it into 4 or 5 that serve the same exact purpose. It exist because it's a gimmick and selling point; that 'floating on air feeling only a Lincoln can deliver'.
