Go Back   Automotive Forums Car Chat > BMW > 3 Series
Old 06-09-2010, 09:22 AM
dougb797 dougb797 is offline
BMW right front grabbing
I have a 2001 330ci and there is a random grabbing in the right front. It is almost like brakes are being applied only in the one quadrant. It is an instant grab and release with a seviere right pull. Noise is a instant grinding sound. It almost sounds like metal to metal. Grab is so pronounced that at higher speed one could lose control of vehicle.
Any ideas would be gretly appreciated
Old 06-09-2010, 09:25 AM
ricebike ricebike is offline
Re: BMW right front grabbing
remove wheel and inspect the front brake pads/rotor/caliper/hose
heck, might as well remove both front wheels and inspect
better yet, bring it to a garage... some will do a visual check on the brakes for free
if you have a personal mechanic, let him inspect it if you're not mechanically inclined
just do it ASAP since this is dangerous
Old 06-09-2010, 09:31 AM
Thanks
This has been done. The condition is very sparatic. Possible ABS issue? Possible bearing issue?
Old 06-09-2010, 09:36 AM
I recently had front control arm bushings replaced. It reduced the problem greatly. Before the problem would result in severe vibration in brake pedal and steering column. This has been resolved but the grabbing is still occuring in the vacinity of the right front wheel..
