Old 06-08-2010, 09:07 PM
camaro12 camaro12 is offline
1998 5.7 losing fuel prime
Hey all, I have a 98 Chevy 1/2 ton, 5.7L and it seems that after sitting for a few hours it is losing fuel prime in the rail. After sitting for a few hours, I pressed the schrader valve in the fuel rail, and there was no pressure. Any ideas on where the pressure is going? Is there a check valve in the fuel rail to stop the fuel from draining back into the lines/tank?
Any input would be great.
Thanks
Old 06-08-2010, 09:34 PM
2000CAYukon 2000CAYukon is offline
Re: 1998 5.7 losing fuel prime
Most likely the fuel pressure regulator (FPR) but it could also be the fuel pump or a leaking poppet of the injector.
The FPR is a very common issue.
//2000CAYukon
Old 06-09-2010, 02:56 PM
Bob B Bob B is offline
When my 97 did this it was the check valve in the fuel pump
Bob B
Old 06-14-2010, 07:50 AM
Chevy-SS's Avatar
Chevy-SS Chevy-SS is offline
//2000CAYukon
Yeah man, FPR is almost assuredly the issue here.
1968 427 Camaro SS
1998 Silverado K1500
2004 Corvette Coupe
2011 Chevy Avalanche
______________________
Old 06-14-2010, 09:24 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
It has 0 pressure after a few hours? I dont know if I'd be too worried about 0 pressure after 2 hours. If pressure drops to 0 minutes or immediatly after, then you have a problem. Are you having a drivability problem?
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
