Old 06-08-2010, 08:46 PM
JeenyusVR4 JeenyusVR4 is offline
Confused?!?
i have been having 2 different problems that i havnt seen before. the first is when i rev the car up (i have a 92 vr4 with minor bolt ons) nd the rpms drop back down to idle a little bit of white smoke come out the exhaust, but only when the car gets back down to idle. i know that usually white smoke is an indicator of burning coolant so i checked my oil for a blown head gasket but nothing.
the second problem is while driving in boost or not sometimes the car just bogs out almost like a hard misfire but it doesnt happen all the time. When in WOT it seems to misfire/backfire quite a bit. I have a MBC set at around 13 and gapped plugs to .035 right now which shouldnt hit fuel cut or spark knock correct???
Any advice would be greatly apprectiated!!
Old 06-08-2010, 10:49 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: Confused?!?
I guarantee its NOT white smoke. So many people have confused oil smoke as being white its ridiculous.
If plugs are fouled, or there is any issue with ignition components you could easily get spark blowout.
Do you have a datalogger? If not, get one.
Old 06-10-2010, 04:08 PM
Re: Confused?!?
ok thanks man but i dont really understand what u meant by it not being white smoke?? i checked the oil in the case a blown head gasket and havin coolant in the oil. but ya i have fairly new plugs wires and coilpacks.
Old 06-10-2010, 05:25 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Re: Confused?!?
What he means is that it isn't smoke, it's steam. Also, just because you didn't find coolant in the oil doesn't mean that your HG is fine or a head isn't cracked. Check for hydrocarbons in the coolant.
AS for the plugs, he's suggesting they're fouled. They can foul in a VERY short period of time. If they're fouled then the spark is weak. At WOT you can get spark blowout. This is where the cylinder pressure actually blows out the spark before it can ignite the air/fuel mixture.
I would suggest checking those two things first.
Stealthee's Avatar
Re: Confused?!?
Fact remains that 85% of people who are having valve stem seal issues make a post and call the smoke white. When its a valve stem seal issue it is obviously burning oil. Oil doesn't burn white.
If its a fuel issue it will be greyish.
Old 06-11-2010, 10:14 PM
Girly VR-4 Girly VR-4 is offline
Re: Confused?!?
it's most likely valve stem seals.
www.groundzeroperformance.com
www.3swarehouse.com
1991 Stealth R/T Twin Turbo... sitting...
1996 Orchid Pearl Stealth R/T.... daily driver duty, 275k+ miles and counting!
1995 3000GT Spyder SL... being modified...
Old 06-17-2010, 01:06 AM
Re: Confused?!?
so i just checked my ECU and all three of the capacitors are leaking!!I wanna fix this problem then buy the tune up kit from 3sx just to eliminate some options.
If any one has some advice on whether to repair or replace would be most appreciated.
Old 06-20-2010, 10:49 AM
Re: Confused?!?
http://www.avproecm.com/
www.3swarehouse.com
Old 06-28-2010, 09:37 PM
Hans_GZP Hans_GZP is offline
Re: Confused?!?
Your plug gap is also too large. You will start to get spark blow out. Gap them plugs to 0.032 at the most... 0.028 will work great.
94 Dodge Stealth TT
94 Dodge Stealth TT, pearl yellow, for sale
93 3000GT VR4, stock, for sale, red
96 3000GT Spyder SL, black, stock, might sell
97 3000GT VR4: stock, for sale, red
92 Galant VR4: TBE, bunch of crap
95 Montero SR: run stuff over vehicle
Old 07-02-2010, 12:42 AM
Re: Confused?!?
thanks Hans ill try that for sure! Ill let u know how it works.
