Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 06-08-2010, 04:18 PM
legotech7 legotech7 is offline
Air Bag Module
Can anyone tell me how to remove the air bag computer module from my 2000 Impala LS? I believe it is under the RF seat, it needs to be reset and if there are any issues I should be aware of; like disconnecting the battery first or disabling the Anti Theft Audio system?
Thanks for any and all info................
Old 06-08-2010, 07:05 PM
maxwedge maxwedge is offline
A990 racer
Re: Air Bag Module
What do mean reset, there is no way you can do this, if there is a code that must be repaired, if the sirs was deployed that is another situation, there is no "reset"
Old 06-09-2010, 04:58 PM
Re: Air Bag Module
Yes, I meant repaired, no air bags deployed, but the air bag light on the dash stays on all the time. There is a company called Air Bags .com that will repair and reset the module. I just need Info on how to remove the module.................
Old 06-10-2010, 07:44 AM
A990 racer
Exclamation Re: Air Bag Module
How do you know that is the problem without a scan for the code, could be anything else. Mine was a bad clock spring in the column, same symptoms.
Old 06-10-2010, 03:25 PM
Re: Air Bag Module
Ok, so can they scan for the air bag light at, like Auto Zone, where they do the scans for free, or do I have to take to the dealership?
Old 06-10-2010, 07:27 PM
A990 racer
Re: Air Bag Module
AZ cannot do this you need a high line scanner, most good shops have the ability to at least get the code. Call around, if not then the dealer.
