Go Back   Automotive Forums Car Chat > Chevrolet > Beretta
Old 06-08-2010, 09:53 AM
cj091184 cj091184 is offline
92 gtz runs poorly
Hi everyone, 92 beretta gtz 2.3 quad 4 DOHC, 5 speed.
OK, so my friend bought this car in this condition, it seems like its running very rich you can smell the gas when its running, ifyou try to hit the gas any faster than very slow it bogs down and then backfires alot wich is how he blew the exhaust off on his way home, yes the exhaust is gone front to back and I know this aint good but would like to see some improvement in the engine before we buy all new exhaust, if you push on the accelerator slowley you can smoothly bring up the rpms but if you let off to quick it will backfire very bad.
Flashed codes, 12 , 41 , 16,........41 is 1x sensor or cmp but this car does not have one that I can find, also if I try to put in a jumper wire while its running the car stalls is that normal.
any ideas or thoughts would be greatly appreciated, also I am going to test fuel pressure and some ignition system sensors later, will post results
