Old 06-07-2010, 07:03 PM
gta333 gta333 is offline
2000 s10 truck codes
Does anybody know of a site that will list all the codes and what the mean I have a sensor but it didnt come with a list of codes. Thanks gary
Old 06-07-2010, 07:16 PM
old_master's Avatar
Advisor/Moderator
Re: 2000 s10 truck codes
What codes are you looking for, RPO, SPO, or DTC's?
You have to know how it works,
to figure out why it doesn't.
Old 06-08-2010, 09:28 PM
The codes P4052 and P4052p/d seems to come up. Thanks for getting back Gary
Old 06-09-2010, 08:29 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Here are OBD11 code list.
http://www.troublecodes.net/OBD2/Pcodes.shtml
But I do not see any P4052 or even 4000 series codes.
What problem are you having and will codes clear and not come back?
What kind of code reader or scanner are you using?
MT
Old 06-09-2010, 12:16 PM
old_master's Avatar
Advisor/Moderator
Is it possibly showing P0452? That DTC indicates a problem with the EVAP pressure sensor showing a lower than expected pressure reading in the fuel tank. Not necessarily a bad sensor, just a low reading and it needs to be checked out. The P0452pd means it has failed more than one time, the "pd" means "pending".
