Old 06-07-2010, 04:56 PM
AznDragon533 AznDragon533 is offline
Mechanic charged me for $400 and my car wont even work.
ark flywheel with clutchmaster stage 1, 2007 hyundai tiburon se
he said i needed a dual mass flywheel? whaT!? everyone on the internet told me single was fine
pull style clutch, The "sticker" fly wheel (spine) (pop outside) side goes to the flywheel. Are we doing something wrong here?
now he put back the car , clutch wont engage, cant drive car.......$400 gone............suggestions!?
thank you for your time
Old 06-13-2010, 09:45 PM
HeWhoKillz HeWhoKillz is offline
Re: Mechanic charged me for $400 and my car wont even work.
If the clutch doesn't engage, I'm assuming it hasn't been driven and is still at the shop? Or atleast parked outside the shop or something? Id take it back and make him fix it. I might suggest making a video that the car won't engage. In case you have to take him to court, with a receipt for the work he supposely did and a video showing what isn't working, you should be able to either get your money back or make him fix it.
Old 06-21-2010, 12:00 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
A letter to the BBB and the local chamber of commerce helps, too.
If he has a warranty, then he should honor it. If not, let him know that he needs to fix it or you can have it repaired by another shop and then sue him in small-claims court for the cost plus any rental fees due to negligence. But if he put the single-mass clutch in as you told him instead of the needed dual, then he has a leg to stand on against you. I would have gone to a different shop for a second opinion on this setup if this were an issue. Good luck!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
