Old 06-07-2010, 12:35 PM
icemike icemike is offline
abs light
i have a 1999 pontiac grand prix had to replace front brake line from pump to caliper pasenger side. bled brakes and now abs light is on.is there a reset for abs light.
Old 06-07-2010, 01:38 PM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: abs light
If the abs light comes on and stays on there is a fault during its start up self check. Once the problem is resolved the light will go off.
Make sure the connections and wires are good on the side you where working on. They are known for wheel bearing/sensor issues and well ass corroded broken wires in the sensor harnesses.
Old 06-07-2010, 07:13 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: abs light
As Airjer said this sounds like a bad wheel sensor. Unfortunately, the hub, bearing and sensor are all one unit and must be replaced as such. It could be on either side so you may want to get it scanned with an ABS capable scanner prior to repairs. If you don't want to spring for the diagnostic then replace both of the front bearings.
