| Cavalier Problem Diagnosis Got a problem you can't fix? We can help. |
I've read several forum threads here and I haven't seen my issue, quite yet.
I have a 2002 Pontiac Sunfire 2.4L 4 door (AT) with 132K miles on it. I have been having a little bit of difficulty for a year or so with the key not always wanting to turn without jiggling it a bit, since I've had cars before with this issue, I just fiddle with it til it turns. A few weeks ago, I turned it on, and though the engine was running, it prevented me from shifting out of park, then I noticed that even though the engine was running, the AC wasn't working, and the gauges were not working. I even revved the engine a bit to make sure that my ears were not fooling me with the engine running, discussed it a bit with my husband (in passenger seat), then turned it off. While discussing whether we should get his keys to take his car, then I tried it again. It turned over, ran just fine and I forgot about it as a one-off anomaly. (Note: I never keep more than 4 keys and a few plastic key fobs for the grocery stores on my key ring, because I don't want the weight to mess up the ignition. I have a second key ring for my work keys that is kept separate.) Last Friday, I'm getting ready to come home to start my one week vacation, and it did it again. So, I turned it off, waited a couple seconds, and tried to start it again. I saw the "Theft Deterrent" light on the dashboard and tried to turn the ignition off. It wouldn't turn off at all. It stayed running the whole hour until the tow truck showed up, and I gave myself a blister trying to get the ignition to turn off. After reading all the various older posts about the Passlock 2, which I verified is the system in my car here http://64.85.6.118/diagrams/diagrams.asp MODEL YEAR(S): SUNFIRE 2000 -2003 KEY: N/A T-HARNESS: GM-7 IMMOBILIZER: GM's PASSLOCK 2 ANTI-THEFT System, Requires: 791 Bypass Module The tow truck driver pulled the fuel pump fuse to get the car to shut off, which occurred to me just about the same time that she did it. Then she disconnected the shifter linkage, so it could be put in neutral to tow it. As it was now 10PM by the time I got home, all I was worried about was running the battery down since it was still "on". I disconnected the battery and came in to wait til the morning to start researching. Now, I discover that I should not have disconnected the battery. I wonder if it could be the magnet inside the ignition that is preventing it from turning off. It did feel like there was some thing inside preventing it from inserting completely and possible for the key to be pulled out while in the on position? Has anyone else come across this situation happening? I'm curious if anyone knows approximately how much I'd have to pay for the ignition and, if necessary, the BCM? This will determine whether I take my car in now, or wait til I can get more funds in. I don't want a shock at the mechanic's. (I can take hubby's car for a while if necessary.) Because of the airbag, I'm very reluctant to try to replace the ignition switch myself. I know when I'm in over my head, and this is one of those times.
Thank you for your help! Talk to you later, Katsnake |
Re: Possible Passlock 2 issue?
Did you ever figure out the problem? I have a 2002 cavalier with the exact same problem.
| Tags |
| passlock , pontiac , sunfire |
