Old 05-05-2003, 12:00 AM
4GZChatch's Avatar
4GZChatch 4GZChatch is offline
Send a message via AIM to 4GZChatch Send a message via MSN to 4GZChatch Send a message via Yahoo to 4GZChatch
New ECU for my ZC
Hey all, I have a chance to pick up a PG7 ECU for my ZC powered civic, and wondered if it will work for my car. Anyone have any ideas?
Remember: You can't spell Crap without APC!
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Hyperco GenII suspension
Progress sway
SAFC
etc. etc.
Old 05-05-2003, 12:04 AM
91civicDXdude's Avatar
yes it will work with no problem. mounting is a different story. You'll have to remove the board from the case and swap it with your PM6 Si ecu so it will bolt in. otherwise, the bolt holes dont line up, but to answer your question, yes it will work and probably do a damn good job with the ZC.
Old 05-05-2003, 11:12 AM
kris's Avatar
kris kris is offline
Off playing with fire.
Re: New ECU for my ZC
Loser, you didnt believe me. :finger:
Old 05-05-2003, 11:54 AM
91hatch 91hatch is offline
Send a message via Yahoo to 91hatch
i have the same ecu pg7 in my dohc zc works great
Old 05-05-2003, 12:12 PM
4GZChatch's Avatar
Loser, you didn't believe me.
I believed you, I just wanted to see what people think of the mounting issue. It's in a totally different box... as you can see from above.
PS. It's not nice to flame on these forums!
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Progress sway
SAFC
etc. etc.
Old 05-05-2003, 01:31 PM
sastanley's Avatar
sastanley sastanley is offline
AF Premium User
Send a message via AIM to sastanley Send a message via Yahoo to sastanley
The PG7 is the Integra ECU isn't it?
Good job dude...What ECU are you running with it now? That should be a straight plug&play since it is USDM??
Edit - Sorry, I went back and read your sig...I am sure that the PG7 will do better than the Si ECU - I hear they run a little rich, but that probably isn't a big deal unless you have smog/emissions issues to deal with.
Let us know how it works when you get it in
-Shawn
'91 Civic DX sedan
DOHC ZC, I,H,E, urethane bushings and mount inserts, rock chipped hood, some rust, stock steelies, nice comfy Integra seats, and the A/C works! What else could you want from an 18 year old car with 241,000 miles? Working on getting the Si tranny in now
Old 05-06-2003, 02:17 AM
2000dollarZCbs 2000dollarZCbs is offline
Send a message via AIM to 2000dollarZCbs
i agree with them, that ECU is FUNNN, i have one in my hatch. and it works wonders. you will notice though it lets you rev out higher then normal, be carefull with that, you can cause damage to your motor if you do it enough.
Old 05-06-2003, 10:06 AM
ev0lution7 ev0lution7 is offline
Send a message via ICQ to ev0lution7 Send a message via AIM to ev0lution7 Send a message via Yahoo to ev0lution7
um OK the redline on the ZC is 7200rpm the PG7 and PM7 ecu have a redline of 7200rpm how will that cuase damage to his motor??
and if u want a little more UMFFFF then go with some BCPR5e-11 plugs by NGK that will not only help you pass smog but will help you burn off that "extra" gas and give u a little more power around 4Krpm and up to redline i know it made a big difference on mine made my motor a little hottter though so make sure u have a good thermostat and radiator and change the oil regularly
Crxce- theoretically if u laid a starter on a table and hooked up the wires would it run???
BLU CIVIC- no...it doesn't have any legs
Old 05-06-2003, 11:50 AM
kris's Avatar
I was just messin around. :silly2:
Old 05-06-2003, 01:02 PM
Actually, the PG7 integra ECU has a 7500 rpm rev limit. the PM6 has a 7200 rpm rev limit. I have verified this with my Field SFC-VTEC, which has a digital tachometer. the tach in the dash shows about 7800rpm, its very innacurate.
Old 05-06-2003, 03:20 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
Is this true? I want to be able to put my PG7 board into the civic ecu case but ive heard that the board is too big and wont fir correctly...
Old 05-06-2003, 05:02 PM
4GZChatch's Avatar
Me too! You take things too seriously!:flash:
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Progress sway
SAFC
etc. etc.
Old 05-06-2003, 07:22 PM
you heard wrong. it bolts right in.
Old 05-06-2003, 09:57 PM
thanks, thats good to hear.
Old 05-07-2003, 03:33 AM
4GZChatch's Avatar
Oh yeah, one other thing...
Everyone keeps talking about how the teg ecu gives you a higher rev limit, but my Si ecu already gives me a little more than <font color=red>7000 rpm's </font>now. What gives?
<font color=blue>sorry, i'm learning html and it's pretty cool...</font>
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Progress sway
SAFC
etc. etc.
