Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 06-06-2010, 05:21 PM
saturntech's Avatar
saturntech saturntech is offline
hi voltage
I have 97 jeep tj 4.0L voltage gauge is right to the max with the check gauge light on. Also batt is flat as soon as I turn it off, when it is running my gauges go all crazy, I'm assuming its the voltage reg in the alternator???
Old 06-07-2010, 11:56 AM
saturntech's Avatar
Re: hi voltage
so I just learnt that the pcm controls the voltage regulator, so I don't know if I should change the alternator or pcm, some input on this would be great!
Old 06-18-2010, 02:12 PM
mastertech1964 mastertech1964 is offline
Re: hi voltage
whats the actual charging voltage at the battery with a voltmeter?, the green/orange wire to the back of the alternator controls the field
Old 06-19-2010, 10:36 AM
saturntech's Avatar
Re: hi voltage
yeah I checked at the batt. I rolled the dice and changed the alt and that was the problem thanks though !
