Old 06-06-2010, 12:12 AM
parkerb parkerb is offline
seat looking a bit worn, what to do
hi all, my '00 cargo's driver's seat is worn. when i ask the parts guy at ford about a replacement he makes it sound like it's impossible due to safety concerns. i can only replace the fabric or foam/ insert- not an entire chair.
what is everyone else doing? i don't see driver's chairs on ebay often. can i swap in the passenger seat and delete the arm rest?
tia,
parker
Old 06-06-2010, 12:03 PM
ricebike ricebike is offline
Re: seat looking a bit worn, what to do
i've seen it done in a ford e150 cargo van
either that or you painstakingly remove the foam / covers from both and swap them over
or just put a seat cover over it
Old 05-03-2011, 11:01 PM
Windstartled Windstartled is offline
Assuming you have fabric, non-power seats removing them and installing new ones is very easy. Those seats are single-piece units fastened to the tracks with 4 downward-facing bolts (NOT the 4 larger bolts that fasten the seat base to the van's floor). Just remove the nuts, pull seat out (without the base they weigh very little), drop new seat in, screw nuts back on.
You can of course use the passenger seat as a replacement or you could go to a boneyard and pick a driver's seat in good condition there for cheap, maybe $20-$25. That way you get to keep the armrest.
Old 05-04-2011, 09:11 AM
12Ounce 12Ounce is offline
I would aproach an upholstery shop that works on auto interiors and convertible tops. There is usually one or two around major cities. Ask a local used auto center who they might refer you to.
Old 05-04-2011, 10:56 AM
phil-l phil-l is offline
Related question: Does anyone know a source for NEW seat cushion foam for Windstars?
2000 Windstar LX 3.8
1995 Contour GL 2.5
1986 Mustang GT 5.0 --> Sold, but missed on sunny days
Old 05-05-2011, 01:03 AM
Not surprisingly there is no part number for cushion foam. I would go with 12Once on this one and suggest an upholstery shop. The alternative would be finding out which contract manufacturer supplied the original seats and try to obtain the material from them, but it's a long shot.
Tags
chair , replacement , seat , windstar
