Old 05-04-2003, 10:41 PM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
Cool 4wd civic
so much stuff i need to do to my car....but i've started my search for a donor car.....decided not to sell my hatch but to improve upon it.....
might go for the b16a1 swap just b/c i plan on adding endyn's supercharger....but i'm looking for a 90-91 4wd wagon to turn my civic into a 4wd....i've looked at that crx they converted to 4wd but i don't think that's going to help me since they used a crv......any helpful info on this subject will be appreciated
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
Old 05-04-2003, 10:48 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
the 4wd from the wagovan wasnt all that great, it always broke down, since the crv is based on the civic platform, it shouldnt be too hard to convert it over.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 05-04-2003, 11:01 PM
BLU CIVIC's Avatar
調整器
yeah but finding a crv price wise v/s a wagon isn't worth it.....besides can't u just build up the awd system on the wagon? replace oem for bette parts??
The name's Adrian
2011 CR-Z - Stock
Old 05-04-2003, 11:02 PM
crxlvr's Avatar
i guess thats feasible.
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 05-04-2003, 11:07 PM
BLU CIVIC's Avatar
調整器
i read that they could only handle 120hp....but i believe i'd have to change too much stuff to put in a crv awd system
The name's Adrian
2011 CR-Z - Stock
Old 05-04-2003, 11:22 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Several problems with a B16a powered AWD Civic.
The AWD Gear box will only fit a D series engine.
The rear diff is VERY weak, as in they are easy to break with the orginal D series engine, a B16a would shred one in seconds.
CRV running gear into an AWD body would be a better idea, but you still have the problem of a weak center and rear diff, as the CRV was never designed to handle lots of hp.
And you would still need to do a lot of custom work getting it all to fit and line up, as the CRV is based on the later EG an EK platforms which is quite differnt to the smaller and lighter EF platform.
If you really really want an AWD Car then go buy a Subaru or Mitsi, Honda's are simply not designed with AWD in mind.
However that said I have seen (and I dont know if I believe it myself) an AWD VTi-R Integra. I knew from talking to a Honda tech who trained in Japan that the enginers played with a B18c powered AWD integra, but he didnt think they ever made any production models. But its possible they did. Unforunatly for anyone out side Japan and anywhere they accepts thier used cars you will never get to see one.
Old 05-04-2003, 11:30 PM
slammedcivicsi's Avatar
slammedcivicsi slammedcivicsi is offline
Yeah what he said.
89 DX: LS Powered
88 CX: Project ZC
Old 05-04-2003, 11:32 PM
BLU CIVIC's Avatar
調整器
skratch out the b16a and insert the sohc....
i'm sure i could make the 4wd system on the wagovan work.....all about being an euthieust (sp)....i just know it'll require some time and stuff like that.....i'm sure it is possible to get the gear box to handle high hp...anything possible
The name's Adrian
2011 CR-Z - Stock
Old 05-04-2003, 11:37 PM
CAptynCrunch CAptynCrunch is offline
True anything is possible, but practical? thats a different story.
I'm all for crazy tinkerings, one of my goals is to convert my cousin's FWD protege GT to a RWD or AWD rotary powered vehicle.
The AWD civic idea however is not a very good one if your going to use the wagon drivetrain. In the long run it would probably be a lot simpler and cheaper to use the CRV equipment. However if your determind, just find a wagon and have at it.
Keiichi Tsuchiya isn't the drift king,
Michael Schumacher Is.
The only thing better than cars is Music... maybe.
Old 05-04-2003, 11:54 PM
BLU CIVIC's Avatar
調整器
AWD rotary protege that would be somrthing to see
what year crv would i use on this venture???
The name's Adrian
2011 CR-Z - Stock
Old 05-05-2003, 01:47 AM
Setanta's Avatar
Setanta Setanta is offline
Send a message via ICQ to Setanta Send a message via AIM to Setanta Send a message via Yahoo to Setanta
I see mto recollect there being an AWD 4th gen sedan... one was imported to Australia according to a friend who's seen it. If so, I wonder what the drivetrain is like on that...
'99 PY DC2R
'85 BBS BMW E30
RIP '90 JDM EF9 Civic SiR
www.performanceforums.com
Old 05-05-2003, 02:27 AM
Moppie's Avatar
Master Connector
Its the same as the Shuttle mate, Iv seen a few of them here in NZ, all ex Japan of course.
Infact they are more common than the AWD shuttle which the silly yanks keep calling a wagon.
The most feasible way I can think of it being done would be to work over a ZC (turbo ) and mount it to the AWD gear box, which Im sure could be fitted with either a gear set from a regular D series g/box, or in some way strengthened.
Then replace the rear diff with one from either an old Nissan 180b, or 200sx/240sx/silvia/whateverthefuckyouwanacallit or Mazda MX5/Miata/hairdresserscar or AWD 323/Familia/fordlazer/TX3i/etcetcetc
It would require custom mounts to attach it to the chassis, and custom work done to the drive shaft and axles to match it all up.
You looking at I guess about a $1,000 worth of work assuming you know someone who can give you mates rates, then you still have to worry about getting it certified, and thats just for the diff.
The G/box would set you back at least another grand, maybe more.
And of course on top of that you have to include the engine, suspension and brake upgrades.
If you had a spare $10,000 lying around then maybe its a doable project, but for that kind of money I would rather buy a GTR Mazda Familia and start with AWD and 240hp.
Old 05-05-2003, 03:10 AM
DarkImportGrey's Avatar
DarkImportGrey DarkImportGrey is offline
Send a message via AIM to DarkImportGrey Send a message via MSN to DarkImportGrey Send a message via Yahoo to DarkImportGrey
if you WERE to convert to awd using a CR-V platform, I would suggest using the 1st gen CRV since it is B-series powered. if i am correct, i believe the new CRV is powered by the K-series.... and i just figure the more stuff you can keep similar the better...
