Go Back   Automotive Forums Car Chat > Buick > Regal
Old 06-05-2010, 05:47 PM
Fire7 Fire7 is offline
Windshield Wipers
I know there have been posts about wipers and wiper motors, but i couldnt find one that was usefull,
I own a 96 Buick Regal Custom v6 3.8 seriesII
My windshield wipers will not work, at first they stoped working, then the next day they worked again, after awhile of them being tempermental they stoped working completely.
My multi-function lever does have a short in it, but Im not sure if it is my problem, the left turn signal will only come on if i pull the lever towards myself a little, i dont have to hold it. but if i push it back it will turn the signal off.
Anyways, My main question is, can i safely hotwire my windshield wiper motor straight to my battery to see if the motor is the problem, I cant find any fuses or relays that are blown. Any tips or advice is appreciated. I really need to get this problem fixed, rainy season has been a pain in the rear.
Also, Im not sure Im looking at the right object when i think im looking at my windshield wiper motor, if anyone can explain where it is that would help me alot as well.
Old 06-07-2010, 03:44 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: Windshield Wipers
The intermittent issue could be the wiper delay module. It's a circuit board attached to the wiper motor itself, and they are known to have issues. The most common is the solder points fail causing intermittent operation. Even though the wiper control is on the turn signal stalk, the wipers are actually a different electrical switch so these are most likely unrelated issues. The pivot assembly that the stalk is attached to contains the wiper switch electrics, and it contacts the separate turn signal switch/cancel mechanism in the column to operate the blinkers.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 06-08-2010, 09:22 AM
So if the delay module is malifuctioning, will it still be running an electric current through it, Is what i mean is how can i test it? or do i just have to replace it and hope it fixes the problem.
Old 06-08-2010, 07:07 PM
richtazz's Avatar
Normally, when they start to go out, if you tap on the module's rectangular plastic cover the wipers will start to work again. That is a tell-tale sign the wiper module (also commonly called a wiper pulse board) is going out and the cause of your issue.
Old 06-09-2010, 07:53 AM
setting here staring at the schematics for my wiper wiring, I realize It doesnt help me find anything, I understand the switch is in the stearing collumn, I understand the moter is behind the firewall, where the f is the module???
Old 06-09-2010, 08:52 AM
richtazz's Avatar
it's mounted right on the wiper motor under a rectangular shaped plastic cover.
