Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 06-05-2010, 05:43 PM
legotech7 legotech7 is offline
Theft Lock System
How do you disable the theft lock system on a 2000 LS Impala?
Old 06-13-2010, 05:48 PM
MallocArray MallocArray is offline
Re: Theft Lock System
Any luck finding out?
Old 06-15-2010, 05:05 PM
No, waiting for some one to post. Also do you have to do this every time you need to disconnect the battery if your working on any thing electronic on these cars?
Old 06-15-2010, 05:12 PM
old_master's Avatar
Advisor/Moderator
Are you talking about Theft Lock for the radio, or Passlock? What is it doing or not doing?
You have to know how it works,
to figure out why it doesn't.
Old 06-15-2010, 05:19 PM
I'm talking about the theft lock. I need to remove the SRS from the car, but the book says to disable the system before doing so. Any comments?
Old 06-15-2010, 05:33 PM
old_master's Avatar
Advisor/Moderator
It's not necessary to do anything with Theftlock unless you're going to install the radio into a different vehicle. If you're reinstalling it back into the same vehicle, it will recognize the vehicle and operate just fine.
What's the problem with SRS system? Is the air bag light on? Are you removing/replacing an air bag?
Old 06-16-2010, 05:54 PM
Yes, the air bag light stays on, not replacing any of the air bags, none of them were ever deployed. So I'm guessing I can just disconnect the battery with out any ill effects if I'm working with any of the electronics in the car or attempting to diagnose the air bag system?
Old 06-16-2010, 06:29 PM
old_master's Avatar
Advisor/Moderator
Improper diagnostic procedures and/or tampering with the SRS, (Supplemental Restraint System) can cause unexpected air bag deployment which can be lethal. Any service work to the system should be done by trained technicians only. That's why your neighborhood auto parts store can not retrieve SRS DTC's, (Diagnostic Trouble Codes).
Old 06-30-2010, 05:10 PM
SierraK1500's Avatar
SierraK1500 SierraK1500 is offline
Exclamation Re: Theft Lock System
Take the car to your local Dealer and have them troubleshoot your problem.
You should disconnect the battery any time major electrical work is done, like replacing the alternator.
The other posters are correct about the radio, and if you get one from a junk yard it needs to be programmed to the car, and its adviseable to get your SRS system checked.
I would not want to be in a position of bag deployment while you are driving on the turnpike or anywhere.
John
Old 06-30-2010, 05:22 PM
Thanks, I will more likely take to the dealer to check it out. The air bag light has been on for almost a year now. I was hoping to save some money by doing some of the work myself. Most dealers are rip off's, when most likely all they have to do is reset the light or something like that!
