Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 06-05-2010, 03:02 AM
jmiller8973 jmiller8973 is offline
hard cold start
i have a base model 97 with the 3.8. when i start it for the first time in 8 hours or so one of two things happen. 1.car starts, idle climbs like normal startup then idle drops and stalls, takes 3 tries or so to stay running. or 2.starts, idle climbs then settles and it idles fine unless i give it gas then the idle drops and it backfires a bit. once the engine is warmed up it runs great. it threw a code for the coolant temp sensor and a code for the cam position sensor. which should i replace first in hopes of a better cold startup?
