Old 05-04-2003, 09:50 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
swap troubles
ok im trying to install my b18a, well i got the rear mount on and i got the right bracket on but its like pulling back, and the drivers side mount is off. then i notice the the tranny is hitting on the front mount, the 4th mount thats not used. which i think is way my drivers side is off, and my passenger side mount is pullinb back
so has anyone else run into this problem, or is my swap just weird
Team Lonely Drivers
Old 05-04-2003, 09:59 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
Has your car ever been in an accident?
Old 05-04-2003, 10:19 PM
not that i know of, i mean minor stuff but nothing major. i think its ok because the mount looked good when it was on the stock dx motor. didnt look all off or anything
Team Lonely Drivers
Old 05-04-2003, 10:21 PM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
When I put in my engine I attached the side mounts first, then the front and rear. If you have no front it should be that much easier.
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Old 05-04-2003, 10:26 PM
yeah but this isnt a d series drop in swap, this is a b series swap. the engine is alot bigger, well maybe not alot but yeah using my ebay generic mounts, the front of the ls is hitting that front chassis engine mount
Team Lonely Drivers
Old 05-04-2003, 10:29 PM
I've never heard anyone with a B-series using a front mount unless you have an aftermarket crossmember, don't use the front mount.
Old 05-04-2003, 10:34 PM
im not using the front mount, like u know what the engine mount bolts to on the chassis, the chassis mount. well my ls tranny is hitting the front chassis mount which causes the engine to be off so i cant get the rest of the mounts lined up and bolted on. like because the tranny is hitting the front chassis mount, the drivers side engine mount does match up and the passenger side mount is like being pulled back
Team Lonely Drivers
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
you have to bend the rear mount area down a bit if i remember correctly, to make it sit right.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 05-04-2003, 10:39 PM
i got the rear bracket on because the previous owner like kinda cut it and made the rear bracket adjustable, if u dont know what i mean, think of hte rear bracket now make the hole width long so u could actually slide a bolt back and forth.
well with taht adjustable rear bracket i got the rear bracket on and i got the passenger side mount on, but the mount is twisted with the eninge pulling it toward the back. the drivers side doesnt mount at all.
its because of the front chassis mount, thats why im wondering if everyone else ran into this problem or this is a unique problem
Team Lonely Drivers
Old 05-05-2003, 12:44 AM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
I'm using the 4th mount on my stock crossmember
Old 05-05-2003, 12:46 AM
mellowboy's Avatar
I think you have to get it in the right angle. It was kinda hard for me to get it in right so i kept tryin different angles till it sits right. Also did u bang ur side wall where the alternator is at? U have to bang it so the alternator will clear right in.
Old 05-05-2003, 05:53 AM
redmanjd redmanjd is offline
cut that bitch off. you have to cut the front mount and put the other mounts in in this order, back , tranny, driver.
95 b18b
new crank, eagle rods, je 10.5 : 1 pistons, 8lb flywheel, stage 3 act clutch, billet aluminium and urathane mounts, balanced rotating mass, 14.3 @ 93mph
New additions, teo4h turbo, ssautochrome turbo manifold, custom piping, turboxs bov, dsm 450cc injectors, greddy e-manage fuel controller 13.07 @ 107 untuned
Old 05-05-2003, 09:19 AM
I think hes talking about the tranny side mount and how it sticks above where the tranny would be so taking it out is a bitch. You have to put the engine in at an angle. That should work. Or try putting the engine on the ground and using the engine hoist to lift the front of the car up really high and slip the engine in from underneath.
Old 05-05-2003, 11:10 AM
kris's Avatar
kris kris is offline
Off playing with fire.
Shouldnt be that hard. Sounds like something is a little messed up.
Old 05-05-2003, 11:25 AM
RedRacerCivic's Avatar
RedRacerCivic RedRacerCivic is offline
Send a message via AIM to RedRacerCivic
Just maneuver your motor around in the engine bay, eventually everything will line up. Even I had trouble getting all my motor mounts to line up when i dropped my d16a6 back in my car.
-1991 Civic Si (Sold)
-1990 Accord EX(Sold)
-2000 Civic Hatch
-1998 Lexus SC300
Click here to see my Shoe!
