Old 06-04-2010, 03:26 PM
whoareyou4 whoareyou4 is offline
98 Blazer 4WD issue
When I select 4WD (I have the 3 button switch), I get a few clicks from the TCCM and then nothing, the 20 amp ATC fuse blows. The other day I removed the Transfer Case Vacuum switch, the ball was difficult to move in and out but I worked with it for a while and it seem to move easier so I reinstalled the switch.
I then tried to engage 4WD and it worked, the actuator appeared to go in and out solidly. When I drove the vehicle and pushed the 4WD button I got a loud whir like it was not fully engaging the front wheels.
The next day I replaced the vacuum switch with a brand new one because when I removed it again the ball was real difficult to move. Now I am still blowing the ATC fuse. The connections to the shift motor are good and clean, as well as the connection to the switch near where the actuator cable enters the front diff.
It looks like a mouse may have eaten through part of the casing on the actuator cable so I am replacing the cable this afternoon. If this does not work than I don't know what else to check. The way the front end was engaging the other day I feel confident I have vacuum at the actuator, I can't check now for sure because the fuse blows so quickly. of course there could be a bad ground somewhere but I don't know where to check.
Any ideas? Am I missing something?
Old 06-04-2010, 04:26 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 98 Blazer 4WD issue
If it is blowing fuse you have a short some place.
I would start unplugging until you find short.
Check a wiring diagram to be sure but I think the fuse is tied into some other stuff besides 4W shifting stuff.
Also grounding pin 13 on diagnostic connector should read out codes if you have any.
MT
Old 06-04-2010, 04:42 PM
MT-2500's Avatar
AF - Advisor
The ACT fuse only powers the transfer case control moduel on yours.
But then the module powers the transfer case motor from ACT fuse power.
Check for shorted or overloaded motor and wiring.
Check amp draw on motor if 15 or more amps you have a motor problem.
MT
Old 06-04-2010, 05:11 PM
The connections on the TCCM are good and clean as well as the connections to the encoder motor. I believe the encoder motor is good. Connections are good at the 3 button switch
Old 06-04-2010, 06:02 PM
MT-2500's Avatar
AF - Advisor
If blowing fuse you have short or motor pulling to many amps.
Check motor amp draw.
MT
