Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > Firebird Discussions
Old 06-04-2010, 10:18 AM
importeater38's Avatar
importeater38 importeater38 is offline
Send a message via Yahoo to importeater38
hard starting on 94 t/a
Its takinga while to start my 94. I turn the key and it turns over but doesnt start until i hit the gas pedal. Sparkplugs? fuel injectors? suggestions?
93 trans am hurst shifter and zo6 rims. 94 trans am GT. functional ram air hood w/k&n air box, ROH rims, toyo skins, Borla cat back SS, TB bypass, de-screened MAF, BBK underdrive pully, Mieziere electric water pump, spec stage III clutch. '06 Yukon Denali XL, black, loaded. http://www.cardomain.com/ride/711131
Old 06-10-2010, 11:09 AM
iron renegade iron renegade is offline
Re: hard starting on 94 t/a
I would probably see how much fuel pressure you have while starting it. Then test fuel pressure after you turn engine off, and watch for it to drop. Pressure should hold solid for at least 30 mins. If it drops off fast, means that your fuel pump is worn and cant hold pressure in the lines. Its a fast and easy spot to test or eliminate quickly
Old 06-22-2010, 09:17 PM
zaktom zaktom is offline
I have the same problem with my TA. I have checked everything and I am chalking iy up to bad check vealve in my fuel pump. Funny thing is, I just bought new one off of e-bay and it was bad from the start. If it is starting hard, I just turn the key off and then try again and it usually pops right off.
