Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 06-03-2010, 10:07 PM
kray001 kray001 is offline
will not start
I a have a 99 mustang with 3.8. has fire and fuel pressure at rail. tries to start but acts like out of time. Check cam and crank sensors. checked all grounds. all seem to check out. any advice where else to look
Old 06-05-2010, 04:59 AM
Davescort97 Davescort97 is offline
Escort guy
Re: will not start
Welcome to AF!
Have you checked the fuse for fuel injectors under the hood. The CKP (Crank Positon Sensor) operates on very low voltage. Make sure the harness connections are clean and tight.
Old 06-05-2010, 09:15 AM
Re: will not start
I've checked all the fuses and made sure I have my reference voltage to my sensors. Plugs are wet.
