Old 06-03-2010, 04:34 PM
laxman21's Avatar
laxman21 laxman21 is offline
Coolant leak
Drivers side, seems to be towards the rear, was dripping off the tranny and steam was coming of the exhaust cross member. was about 2 ticks above the 210* mark, not overheated.
Did this when I stopped in my drive way, leaked out about a half gallon or less. Refilled with coolant and started with no leak and was running about 205*. Drove it a little with no leak when I stopped.
ETA: I don't think this started until I had stopped and turned off the engine.
Thoughts please.
'92 s-10 4x4 EC p/u
'99 Blazer LT
'99 Suburban LT
Old 06-03-2010, 09:00 PM
blazes9395's Avatar
blazes9395 blazes9395 is offline
Newbie mod
Re: Coolant leak
Best way to check it would be to get a pressure tester on there and see where its coming from. On driver's side, you have intake gasket, the heater lines are on the passenger side, but I wouldn't rule that out. Best way to see would be get a pressure tester on ther and take a close look and see where its coming from.
