Old 06-03-2010, 02:35 PM
Heater Core Heater Core is offline
Dipstick
The dipstick on the Ford F150 series pickup is weird. Most dipsticks you can tell whether or not you need 1 or 2 or more quarts of oil. The Ford dipstick has about less than an inch of an indentated area at the bottom of the stick where you can see oil on the stick and it reads at the top end "Max" and at the bottom end "Min". That makes no sense to me. Can anyone tell me how to read this dipstick? Is Max full and Min empty? That doesn't make sense.
Old 06-04-2010, 12:12 AM
mechhound mechhound is offline
Re: Dipstick
I assume the max is the maximum amount of oil you should have to safely operate the engine and the min is the minimum amount of oil you should have to safely operate the engine. It would be less confusing if it said "safe operating range" between those marks. Even though most modern engines use very little oil, check your oil often.
Old 06-04-2010, 06:22 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: Dipstick
Max is when the oil is completely filled. Min is the minimum safe operating oil level. Usually the min mark is about one quart low.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
