Old 06-03-2010, 03:25 PM
cbushrow cbushrow is offline
1996 F250 Powerstroke keeps burning up starters
my 96 f250 powerstroke keeps eating starters. About every 6 months I have to replace it. I have tried different brands, stater solenoids, and batteries and I cannot figure this out. Any help would be greatly appreciated. Thankyou
Old 06-03-2010, 05:04 PM
MsRae MsRae is offline
Re: 1996 F250 Powerstroke keeps burning up starters
How does it sound when you start it, does it grind or continue to "spin" after you have released the key? When you get the starter tested what is the part that is bad? Have they told you if it is the solenoid or the brushes?
One thing I have seen happen is an exhaust leak or routing has been routed too close to the starter. Is there a sheild on the starter? If they get too hot I have seen that create issues with them.
Old 06-04-2010, 01:55 AM
fordtrucksonly's Avatar
fordtrucksonly fordtrucksonly is offline
Could be a damaged or warped flywheel.
"When Lightning Strikes the Heartbeat Stops!"
'91 Mustang LX 347 StRoKeD & BlOwN
'04 Ford F-250 6L PS FX4
'95 Ford F-150
Ford Racing Pride
General Motors who?
2004-2008 Ford Master Certified Technician
Old 06-04-2010, 04:13 AM
The starter has never made a grinding noise and it always shuts off when I release the ignition switch. I will definately check in the brushes.
Thank you for the info on the flywheel, I will check it out asap.
Old 06-05-2010, 09:09 AM
jyount jyount is offline
Stock style starters suck, I replaced mine with one too. Then I put a good one on it. Search for user dbelectrical on ebay. Get the side drive gear reduction starter. About 145 bucks shipped to my door when I got one, cranks WAY faster than the stock one ever did. Ever notice how super duties crank so fast? They have the same style starters.
It is two bolt instead of our three, but it mounts right up, just don't use one bolt. All the super duties are two bolt, starters from them work too, but expect to spend some coin for one at napa....
10 hours away from John Deere master certified
also master certified ASE tech. Exp. in both.
Went to school for cars, wound up staying with Deere dealer for a while, so schooling there too. Also couple years exp in GM and some GM training
Gave up wrenching for "Greener Pastures"
Current job: RN
2010 Silverado Z71 5.3L 65xxx
Wife's
2007 Suburban 1500 LTZ 5.3L 102xxx
