Old 06-03-2010, 02:49 AM
Pedro71988's Avatar
Pedro71988 Pedro71988 is offline
Send a message via ICQ to Pedro71988
Subaru Impreza, 1/24 Fujimi
After a long and bloody fight, I finished this Subaru, which is almost stock out of box. I had only removed all the logos and the rear wing.
In essence, it was already finished some time ago. But it was much worse, then thie version, although this one is far from ideal .
But after the many problems, which I had with it, I'm really happy with the result
Old 06-05-2010, 10:10 PM
ravan17 ravan17 is offline
Re: Subaru Impreza, 1/24 Fujimi
looks good, i think if you paint the lug nuts black or silver it would give it a MUCH more realistic effect
Old 06-06-2010, 03:13 AM
Pedro71988's Avatar
Thank you for your suggestion, I've corrected it now.
Old 06-15-2010, 09:41 AM
Pedro71988's Avatar
Some new otuside pics
Old 06-20-2010, 03:23 AM
ben_gsr2s's Avatar
ben_gsr2s ben_gsr2s is offline
Hi..
maybe the wheels too small..
and also the ride height.. it looks weird
i'm planning to get this kit.. any advice?
Old 06-20-2010, 04:50 AM
Pedro71988's Avatar
Hi.
This kit has a really good overall fitment and it's easy to build. Almost no molding lines and a really detailed suspension.
As you wrote, the wheels are really small, they don't look like 17", but more like 15" and the shocks are bit to long, you've need to cut them and lower the suspension. If you're going to use som other wheels, you need to drill a bigger hole in to the breake discs, otherwise, they won't fit. This is why I haven't used other wheels, because I had the whole car build and wanted to use som Fujimi 18" wheels, but I didn't get them there.
Also the fitting of the chassis into the body is a bit complicated, but with a little of pattience, you will get it there.
Old 06-20-2010, 09:16 PM
the rim size might be off just a tad bit, but i dont think the ride height is off by too much. but then again, when you get into scale modeling even 1/16" of an inch makes a huge difference. but as i said before, a bit more realistic wheels and maybe a licens plate would really make it much more realistic, especially for pictures!
