Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 06-02-2010, 08:43 PM
Cavalier9696's Avatar
Cavalier9696 Cavalier9696 is offline
Send a message via Yahoo to Cavalier9696
Oil Feed line.
K a friend of mine has a 97 i think gsx. The problem is, his feed line started to leak so he bought a new one. But to get him by till his new one comes in, he put a 5/8 transmission hose(which I know the original feed line is alot alot smaller) on. He has no leaks, but as soon as he cranked it up and drove it down the road it died.
Now it won't crank. He pushing to much oil cause the hose so big? Not sure if it's a fuel problem cause it ran fine before he put that hose on.
1995 Eclipse RS 5psi
Garret T3/T4 Turbo, Procharger FMU, TurboXS BOV, OBX Evolution 35mm External WG, HKS Intercooler, Apexi DP, Apexi exhaust.
Old 06-03-2010, 02:05 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: Oil Feed line.
Too much oil to the turbo will cause the bearings to fry out on it. But it will only flow as much as the smallest hose allows it to. It won't cause the motor to shut off and not allow it to crank.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 06-04-2010, 10:59 AM
Re: Oil Feed line.
Turns out the 30amp motor fuse under the hood was blown. Put another one in and it blew within seconds. As soon as he gets on it, it blows.
Old 06-04-2010, 01:20 PM
david-b's Avatar
Dave is THAT guy
Re: Oil Feed line.
Definitely have a short somewhere. Need to find out what's causing that.
75 Monte Carlo
Old 06-05-2010, 10:12 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Oil Feed line.
All MHI turbos have built in oil restrictors. You can run as big of a hose as you want to it wont hurt anything.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 06-22-2010, 04:01 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Oil Feed line.
Something is shorting either when the motor rocks in the mounts, or when the throttle cable moves (I've had the cable cut through my CAS wiring before and start a fire).
To give you a place to start, here's a list of things powered by the 12v MFI feed on a 2g turbo harness:
ECU (pins 25 & 12)
All 4 injectors (via resistor)
ISC
All 3 emissions solenoids
WG solenoid
MAF
Crank and Cam sensors
Front and Rear O2.
The rest of the 12v stuff in the engine harness is fed by the ignition switch, so you shouldn't have to worry about any of this:
Fuel pump relay
ECU pin 82
Coil pack
Transistor/Ignitor
Starter circuit
VSS
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
