Go Back   Automotive Forums Car Chat > Toyota > Pick-Up
Old 06-02-2010, 07:35 PM
oldblue120 oldblue120 is offline
90 4x4 diff ???'s
I have a v6 toyota and need a little help my pinion bolt came loose one day some how while going down the road and started vibrating real bad so i tightend it down but mabie to tight because it went away for a couple of days but started again so i checked the diff. by rocking the drive shaft and it had some play about a 1/4 inch back and to so i took the diff out to check it and it seemed fine the 1/4 inch wasnt there and the axle splines didnt look bad any ideas???? one wheel bearing was bad but i dont think it would cause that much play oh yea i couldnt turn the diff by hand when i took it out but i did impact the pinion bolt down to so i backed it off and it spun fine
Old 06-05-2010, 09:22 PM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
Re: 90 4x4 diff ???'s
A little play is normal, esp in a 20 yr old truck.
There is a specific torque value for the pinion nut, which i can't think of right now.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
