Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 06-02-2010, 04:07 PM
bhw33191's Avatar
bhw33191 bhw33191 is offline
Send a message via AIM to bhw33191
Identifying the date of my engine
The only numbers i've been able to find are 10066036 (located on driver side rear ledge. I'm pretty sure that indicates i have an LM1 Goodwrench crate motor. There are two sets of codes on the front passenger side right under the alternator "1M1009" and "7VP"...not sure what these mean. And then under the valve cover i found "83417869". Not sure what that means either. From the research i've done, i have not been able to find a code that looks like a date code. Can anybody help?
'83 Caprice Classic LM1 (truck) 350 swap. about 200HP, 305 ft/lbs..for now.
-- 65,000 original miles --
Old 06-02-2010, 08:53 PM
j cAT j cAT is offline
Re: Identifying the date of my engine
see if you can find something like this :
Engine ID Code Example: V0107CLJ - (V = Plant, 01 = January, 07 = 7th Day, CLJ = Engine Suffix Code)
Another example: T0830CTY - (T = Tonawanda, 08 = August, 30 = 30th day, CTY = 1970 396 Camaro, 375 hp, 11.0:1, TH400)
with the engine suffix code [like CTY] this can be decoded to find year manufactured ...
Old 06-02-2010, 10:53 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Is your block left or right dipstick? Pre-1980 blocks are on the left (driver) side, =>1980 blocks are on the right side.
On the pre '80 blocks, pull the timing cover off and the block casting # is located there. The stamped numbers in the pad on the right side to the top of the water pump are the numbers that jcAT above noted, and also the cars' VIN (the last 8 digits only).
The '80-up blocks are also like that, but have the last 3 digits of the block casting cast into each side of the block, above the pan rail (example, 207).
Casting numbers can generally be found also on the transmission flange, and dating information on the right side of the block. You might see a 'clock' shaped marking with a 'hand' pointing to a dot (indicating hour of pouring), another 'arrow' pointing at a D or N (day or night shift), and a number such as G 26 7 where the first digit is a letter that indicates month (A = January, G = July etc), 26 indicates day of month and 7 is last digit of year made (in my case here, '87 for July 26th 1987).
You can get casting information from www.mortec.com ...
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 06-03-2010, 02:08 PM
bhw33191's Avatar
After all my research, its a Goodwrench crate motor. I found a huge list of engine casting numbers, most of them list the years the engine could be but when i find my numbers...no year listed..so i'm assuming this means its just a universal engine, and the design has not changed.?
The dipstick is on the passenger side, but there IS a hole on the driver side to put it also, it just has a plug in it.
I believe i found some kind of date stamp, its a circle made of dots with a line in it. Can't remember what it looks like exactly but i'll have to check again.
Old 06-04-2010, 12:31 AM
silicon212's Avatar
Confoundingly Lucid
Yeah if it has dipstick provisions on both sides, it's a hecho en mexico Goodwrench crate motor.
