Old 06-02-2010, 08:09 AM
daarrve daarrve is offline
hard to start
Good day. I am hoping someone can help me with my truck. I have a 2000 Chevy Silverado, 6 litre, 8 cylinder 2500 series. I am having difficulty starting my truck when the engine is cold, this morning and yesterday morning, I cranked it for about 10 seconds before it caught, then is sputtered for a few seconds more and was blowing black smoke, at least I think it was black. Then when I got to work today I left it and came back about 10 minutes later and it started great. Yesterday afternoon after work it had been sitting for aboout 7 hours it did the same thing. I also hooked my truck up to a scanner this morning, the closest vehicle I could get was a 2004 Silverado, it threw the code P0141. I am planning on checking the fuel pressure in the next few days whenever I get a chance. Thank you for your VALUABLE help.
Respectfully, Dave Clark
Old 06-02-2010, 08:57 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: hard to start
HOW MANY MILES ON IT AND WHEN WAS LAST GOOD TUNE UP?
Check engine cold and engine cranking fuel pressure.
And watch for fast leak down after shut off.
If pressure is not up to specs injectors will not squirt fuel on a cold start.
Post back your fuel pressure readings.
MT
Old 06-02-2010, 09:15 AM
Re: hard to start
It has 202k miles (326k kilometres) on it. I replaced the plugs about 2 months ago along with changing the tranny filter and fluid. I am going to flush the transfer case this weekend too. The fuel filter was reaplced about the same time as the plugs.
Old 06-02-2010, 11:20 AM
MT-2500's Avatar
AF - Advisor
Re: hard to start
We need the fuel pressure readings.
What transfer case does it have?
On the transfer case flush make sure you use the correct fluid.
MT
Old 06-03-2010, 06:10 PM
Re: hard to start
I finally hooked my truck to check the fuel pressure and it is 48 psi, I shut the engine off and almost immediately it dropped 2 psi. I checked it after about 15 minutes and it was at 50psi
Old 06-04-2010, 08:19 AM
MT-2500's Avatar
AF - Advisor
Re: hard to start
Your fuel pressure is to low.
You need 55/62 lbs.
For a cold start engine cranking you need close to 60 lbs for for the injectors to squirt cold.
Could be a weak pump or plug ed filter or low fuel in tank or fuel pressure regulator bad.
To test pump and fuel pressure regulator block off return line and see if fuel pressure comes up.
With return line blocked off you should see 75-90 lbs or more if pump is good.
Post back reading with return line blocked off.
Also with external fuel pressure regulator always pull vacuum line off and look for gas in it.
If so regulator is bad but may or not be the low fuel problem.
The pump has to produce higher pressure and volume than the specs for the pressure regulator to control proper fuel pressure.
MT
Old 06-04-2010, 09:19 AM
Re: hard to start
You need 55/62 lbs.
Can you please tell me the easiest way to plug the return line? Thanks.
Old 06-04-2010, 11:00 AM
MT-2500's Avatar
AF - Advisor
Re: hard to start
There is not a easy button on it.
If it has a rubber hose in it any place you can pinch the rubber hose but not any plastic line.
Other wise you will have to make up a plug depending on where you tap into return line.
Or hook up a gauge at the fuel filter in line and check direct pump pressure.
MT
Old 06-07-2010, 07:35 AM
Re: hard to start
On the chance that I have to replace the fuel pump can you please tell me how long of a job it is, also what is the best way. I have heard 2 ways, lower the fuel tank and also to remove the truck bed. Thanks.
Old 06-07-2010, 10:23 AM
j cAT j cAT is offline
Re: hard to start
sliding the truck bed back until the fuel pump access is revealed is a good way to avoid working under the tank ..easier to access the fuel pump and clean and lube the ring to remove the pump ..also inspect and correct any corroded lines/etc...
in the rust belt, tank removal may mean, tank strap replacing ..
