hid upgrade
upgraded to hid but they wont work properly. they blink like turn signals can anyone help
Re: hid upgrade
Did you do the upgrade, or pay to have it done? Which kit was installed? Did you deviate from the instructions, or were there any portions of the instructions that weren't quite clear to you? Do they both blink together, or is it a somewhat random blink on each side? Do they only start to blink after they've been on for a while, or do they start blinking as soon as you turn them on? Do you have a DMM and understand how to use it?
-Rod |
Re: hid upgrade
they start blinking as soon as i turn them on i tried the same ballast and bulb on my honda and they work fine. i called ddm where i bought them from and they say i might need some error code elimanators to make them work
Re: hid upgrade
What!?! Error code eliminators for HID headlights?
-Rod |
Re: hid upgrade
yup they sell them
Re: hid upgrade
People also sell "performance" resistors for the IAT sensors. It doesn't mean they do what they are advertised to do.
What error codes are these supposed to eliminate? Do you have error codes? -Rod |
Re: hid upgrade
Well, I'll be da......
I was reading a thread on another forum regarding HIDs and stumbled across the following quote... "Flickering issues are not fixed by a relay. The flickering issue is caused because people try to put hids on a car with a can bus system. With a relay harness it wont draw any power from the stock headlight wiring. The canbus thinks the bulb is out, so it will keep turning them on and off to try to correct this. You can get around this by getting the turn on signal from the driving lights instead of the headlight plug. I had to do this on my caliber. Companies kept on trying to make new harnesses by adding resistors but in the end it didnt work out very well. Sometimes it would even cause other electrical issues." Apparently the CANBus monitors the headlight current draw which would help explain the need for a "code eliminator." I have learned my item for the day, I can go to bed now. -Rod |
