Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 06-01-2010, 03:13 PM
unboundmind's Avatar
unboundmind unboundmind is offline
tchr & learner
Arrow Hitch Install Help
i need to install a class 2 hitch. i can see where the holes are in the frame. what i can't figure out is how i'm going to get the nuts for the bolts into the frame when there is no hole in the frame i can see to put my hand thru to put the nut and tightening tool into. any help there?? thanks1
2008 Mazda 3i 2.0L Manual
Take what lands on your plate and transform it into something you can eat.
Ram Das
Old 06-01-2010, 04:52 PM
Mike Gerber Mike Gerber is offline
AF -Advisor
Re: Hitch Install Help
I believe those holes are already threaded. Check that first.
Mike
Old 06-01-2010, 05:43 PM
tchr & learner
Cool Re: Hitch Install Help
Mike
Thanks Mike. Yes 2 holes on each side are threaded. Depending on the hitch there are 2 additional holes to drill on driver side to put u shaped holder in. if the threads are all you need then that is a piece of cake. probably that stuff that seals the threads semi permanently so they don't vibrate out would be good, yes? i figured you needed the nuts to hold it.
Ram Das
