Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 06-01-2010, 02:53 PM
bhw33191's Avatar
bhw33191 bhw33191 is offline
Send a message via AIM to bhw33191
Quick water pump question
Do i need to apply any kind of sealer before i hook it up to the engine? Or should i just keep it a dry seal?
'83 Caprice Classic LM1 (truck) 350 swap. about 200HP, 305 ft/lbs..for now.
-- 65,000 original miles --
Old 06-01-2010, 07:08 PM
j cAT j cAT is offline
Re: Quick water pump question
on these gaskets I use permatex form a gasket sealant ..just coat the entire gasket very lightly let it set for 1/2hour then install...
on the water pumps mounting studs I use thread sealant...this on the threads will prevent thread rusting ...leaks etc...
Old 06-02-2010, 10:18 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Thread sealant on the bolts is all you need, I just install the gaskets "dry". Never had problems in 25+ years.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 06-03-2010, 02:46 PM
Blt2Lst's Avatar
Blt2Lst Blt2Lst is offline
What he said ^^
In addition to that, I use weatherstrip adhesive to hold the gaskets in place, keeps them from moving when installing the pump.
1989 Caprice Classic Wagon, Olds 307 ,SMI Q-Jet, 200R4 w/Shift kit, Flowmaster 50, Hotchkiss sway bars, KYB Shocks. Jet Chip,
1989 Mustang LX 5.0 5sp convertible
1992 Camry LE 2.2
1996 Suzuki RMX250
I'm a victim of circumstance [
Old 06-11-2010, 02:04 AM
bigwar bigwar is offline
Would that also apply to a 1995 Caprice Classic station wagon 5.7L
