Old 06-01-2010, 01:43 AM
type0 type0 is offline
nide a trasmission
hi i am from puerto rico i have a 2000 ford windstar i just bought it las week it hace a bad trasmission i nide a good manual so i can repair the trasmission please i nide help????????????
Old 06-02-2010, 08:25 PM
wiswind wiswind is offline
Re: nide a trasmission
In your case, I would recommend a subscriptiong to www.AlldataDIY.com
I includes all the Technical Service Bulletins (TSB).
One thing I would recommend you look into is the Transmission Range Sensor (TRS) also called Neutral Safety Switch.
They are a KNOWN common failure......
The TRS is mounted on TOP of the transmission case, it is what the cable from the gear select connects to.
Another thing that can look like a internal transmission problem is the Vehicle Speed Sensor, located on the back side of the transmission......kind of above the catalytic converter that is below the transmission.
Very hard to get to, but doable from under the vehicle......by feel.
Of course, don't forget to check the obvious......transmission fluid level.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
Old 06-03-2010, 08:21 PM
tomj76 tomj76 is offline
Also, Motorcraft has online Ford manuals that you can subscribe to. It's something like $20 for a month of access.
