Old 05-31-2010, 07:17 AM
boilrman boilrman is offline
sudden loud ticking
95 LeSabre, 3.8L, approx 140K. Sudden noise started low and continued to increase. Thought it may be in the alternator or idler pulley. Pulled Serpentine belt and started car, noise was gone. Pulled Alt and had tested, no noise. replaced pulley as it was also grooving and saw metal splinters on back side of it. No luck. Noticed when A/C kicked on it got louder, but yet didnt change alot when unit kicked off.
Unsure if it was a fluke or not, but when backing out of driveway, put car in Neutral and noise was gone, back into gear and it was back.
Any thoughts?
Old 05-31-2010, 08:53 AM
maxwedge maxwedge is offline
A990 racer
Re: sudden loud ticking
Tough to diagnose noises from here, if gone with no belt we must assume it is accessory related, also check the balancer for the outer hub seperating.
Old 06-02-2010, 02:23 PM
1Rudycolin 1Rudycolin is offline
i have a 1997 buick Le Sabre at frist it had slight knocking nosie then when i drove it it started to make a clicking noise real fast then started making noises on both sides of the engine it had no power. then oil started to come out of the pully area and right by the vaive covers now when i start it has heavy engine noise on the right side of the engine its fwd so thats the side farthest away what happened to my car. this is the seond buick that this has happend to me same thing the other was a 93 regal custom
Old 06-05-2010, 09:27 AM
Balancer was the issue.
Thanks
