Old 05-31-2010, 06:52 AM
iceman2 iceman2 is offline
AC Clutch will not engage
1993 Civic DX Sedan, 167k miles, 1,5L. AC Compressor does not engage and green AC light on dashboard does not turn on when pressed. Impossible to tell if any freon in the system - thanks for your help. This system uses R12.
Old 08-05-2010, 06:55 AM
BullShifter's Avatar
Re: AC Clutch will not engage
If there is no pressure in the system it can't turn on. If I remeber right there is a pressure switch behind the driver side head light. It's located on an a/c line. Unplug it and stick a paper clip in the two holes. Start the car and turn the a/c on. If it comes on you have no juice. Easiest just to covert it to R134a.
Old 08-06-2010, 09:30 PM
maxassassin's Avatar
maxassassin maxassassin is offline
Send a message via AIM to maxassassin Send a message via MSN to maxassassin
you could also jsut take the cap of the low pressure side of your ac system and take a ball point pen and poke it down to see if theres pressure.
06 cbr 600 f4i
91 civic hatchback.
96 nissan pathfinder
Old 08-07-2010, 04:59 AM
vids1386 vids1386 is offline
you need to set the Air Conditioning to maximum. if it does not blow out cold air then With the ignition key on,unplug the low pressure clutch cycling switch and place a jumper wire across the connector.
If the compressor clutch doesn't click in then first check for Battery Voltage at the connector.
used pickup trucks
