Old 05-30-2010, 04:42 PM
jakegday jakegday is offline
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
removing control arm question
hello. when removing the control arm, you need to loosen/remove the nut from the top of the ball joint. after that, does the control arm just fall out of there, or do you have to somehow force it out? what is the best way to do this?
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
1978 Ford Ranchero GT 302 with a few goodies
Old 05-30-2010, 07:58 PM
ricebike ricebike is offline
Re: removing control arm question
http://www.justanswer.com/questions/...ervice-control
Front wheel
Antilock Brake System (ABS) wheel speed sensor connector and jumper harness from the retainer
Stabilizer shaft link
Cotter pin from the ball stud and loosen the nut
3. Install a ball joint removal tool over the ball joint and lower control arm. Rotate the ball stud nut counterclockwise to separate the ball stud from the steering knuckle.
4. Remove the lower control arm.
To install:
1. Install the lower control arm and bolts. Do not tighten the nuts at this time.
NOTE
Align the ball stud cotter pin hole parallel to the knuckle to ease the cotter pin installation.
2. Install the ball stud to the steering knuckle. On Grand Prix, and 2001 Impala and Monte Carlo, tighten to 15 ft. lbs. (20 Nm) plus an additional 120 degrees.
3. Install or connect the following:
New cotter pin and bend the ends. Make certain the ends do not make contact with the ABS wheel speed sensor
ABS wheel speed sensor wire harness to the retainer clips
ABS wheel speed sensor connector
4. Install the lower control arm nuts and torque them to 83 ft. lbs. (113 Nm)
you can probably rent that tool from a parts store
there's also a way to use a hammer to the side of the ball joint so you won't ruin the boot...
Old 05-30-2010, 09:28 PM
haha, sounds ALOT like my factory service manual. no parts store in my town has a tool like that, so i was wondering if there was another way to do it
Old 05-30-2010, 10:39 PM
sorry i didn't explain it fully
here's a youtube link:
http://www.youtube.com/watch?v=5Pjkf...ext=1&index=27
isn't youtube how-to vids great???
its a saturn, so close enough to get the point on how to pop the ball joint from the LCA... see how he left the nut on the top of the ball joint stud so it won't pop off violently?
if the ball joint is part of the new LCA unit, i guess you can rent a "pickle fork" since you don't have to worry about tearing the dust boot
http://www.ehow.com/video_2327952_us...ll-joints.html
Old 05-31-2010, 12:56 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
or buy a pickle fork. I got mine new for about 8 bucks.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
