Old 05-30-2010, 11:42 AM
caminofan caminofan is offline
hum in front end
Hello everyone.I have a 2004 Trailblazer EXT.There is a hum coming from the front driverside wheel;just like a mudder tire on pavement.Sound is more pronounced at lower speeds such as 30-40 mph,although it still hums ot highway speeds.Just rotated tires and checked ball joints and tie rods,everything checks out.I'm thinking wheel bearing.still makes noise coasting in neutral as well.Anyone hhave any input?Thank you.
Old 05-30-2010, 06:31 PM
maxwedge maxwedge is offline
A990 racer
Re: hum in front end
Wheel bearing, had the same issue with mine, see if any play in the hub but this is most likely the problem.
Old 06-01-2010, 05:08 PM
Jethro Jethro is offline
Send a message via AIM to Jethro
im surprised that when the ball joints were checked the sloppy bearings didnt put out a red flag!
2002 LT Trailblazer 4x4 One of the first of this kind on the road
2003 3500 LT Silverado 4x4 ext cab
2006 Heritage Softail HD FLSTI
Old 06-02-2010, 11:36 AM
There is no slop in front end ,yet.Just the noisy hum.I want to fix it before i get slop and destroy anything in front end.I want to be sure that it is the bearing before i go and replace it.Don't want to fix something that isn't broke.
Old 06-02-2010, 12:07 PM
A990 racer
Get all 4 wheels off the ground put in 4wd and run about 30 mph, listen at each wheel you will be able to tell which one, just be careful doing all this.
Old 06-03-2010, 11:34 AM
what brand tires? Goodrich allterain can be noisy.
Old 06-04-2010, 08:43 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
As maxwedge said get it up and have a look and feel and listen.
Also a quick check is to drive down a straight road about 35-45 MPS and with nobody behind or looking you way turn the steering wheel a little left or right and if noise changes it is almost always wheel bearing.
MT
Old 07-23-2010, 02:21 PM
Ended up replacing both driver and passenger side bearings.That did the trick.I was shocked at how reletively easy and painless the procedure was.Now I can drive down the road without sounding like I'm running 33in mudders.Thank you to everyone for their input!
