Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 05-30-2010, 09:41 AM
jsb1022 jsb1022 is offline
Malibu '07 knocking noise when turning..
I love this car - great on gas, and roomy, comfy. 60k on it. I just had new Monroe Struts and Monroe Shocks put on yesterday. I also had the brake fluid flushed out and new fluid put in, and I also had new front brake pads and the rotors shaved it little. And of course the every 3K miles oil change done. Oh, and I had a wheel alignment done - abviously. When the mechanic was removing the old struts, he said the driver's side Sway Bar fell apart so I had to get a new one.
Before the work, I noticed a knocking noise and it only happens when I am turning the wheel while driving (or) while turning the wheel when it's parked. I was hoping that the work would take care of the noise but it didn't. I did some searching on the Net and came up with one thing that needs adjusted - the steering rack - and it takes 2 hours. So Im here to see if anyone has had this same noise/problem and what was done to fix it. Also, is this something that can get worse if I ignore it? Any guidance is surely appreciated.
Old 06-03-2010, 08:55 AM
91goldbomb's Avatar
91goldbomb 91goldbomb is offline
Re: Malibu '07 knocking noise when turning..
hey just came across this post i have an 06 ltz hearing the same thing when im parked and move the wheel back n forth i hear it also when im turning while driving or occasionally whe i hit a little bump we just bought this car it has high miles on it but for the price we paid its worth it we did get a car fax on it and i did see that there had been steering and suspension work done on it in the past my origanal thoughts are sway bar links maybe just bushings or maybe strut mounts i do sometimes hear it from the back too when i hit a bump if you figured it out let me know i havent had a chance to look at ours yet due to being busy at work
Old 06-05-2010, 08:10 PM
Johnny R Johnny R is offline
You may want to see if the coil spring is broken. Mine was. Here's how to do it. 1 person turns the steering wheel and another person looks at the coil spring, but be sure to keep your head out of the way.
Johnny R.
2011 Malibu LT - It's a beaut. So was my '99!
2006 GoldWing 1800 cc - the way to go, coast to coast!
Old 06-05-2010, 11:04 PM
Ed_Strong's Avatar
Ed_Strong Ed_Strong is offline
Son of a Mechanic
You need to lubricate the Inner and Outer Steering Shaft... Read the first one on the list here TSB #060232007
Also a lot more info to read HERE, follow posts #2 and #12... disregard the advice to use PB Blaster as it will wash all lubrication off the shaft, making it more dificult to lubricate!
Current Rides:
2018 Honda Pilot EX-L - 3.5L V6 -{|}- 2004 Toyota Matrix XR 4WD 1.8 I4
________________________________________
Past Rides:
2000 Ford Windstar LX - 3.8L V6 SFI - {|} - 2003 Ford Expedition XLT - 4.6L V8 SFI
2005 Chevrolet Malibu LS - 3.5L V6 SFI - {|} - 1991 Chevrolet Corsica LT - 3.1L V6 MFI
1995 Dodge Grand Caravan SE - 3.3L V6 MFI - {|} - 1980 Ford Mustang - 3.3L L6 1BBL
