Air Handler
Greetings,
I drive a 1989 buick lesabre 3.8 FWD with the electronic touch climate control. The problem is when i turn on the a/c it only blows from the bottom and top. No air from the vents. I know its a vacuum Actuated system but all the lines are good. any ideals? |
Re: Air Handler
I would suspect the connector @ the programmer has softened and collapsed inside under vacuum. Remove the connector & use 1/8" vacuum hose on each line to replace the connector.
Knowledge can be communicated, but not wisdom! ![]() ![]() |
