Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 05-30-2010, 01:21 AM
shanestieber shanestieber is offline
many problems with 2000 venture
i have an electrical issue that seems to get worse and worse it started with my wipers doing the stopping in upright position the my windows started not rowing up and down all the time now they dont at all, then my back wiper stopped working for a while then started and stopped again, also my electronic door locks only lock the vehical not unlock them, also my gas gauge only works when i have the car sitting still and nothing moving in it as soon as someone moves it goes back to full and stays there. help please. now i also have my air bag light on i have no idea what caused it thinking something electrical again i am pretty mechanically able so i should be able to fix most stuff dont be afraid to get into detail thanks for your help
Old 05-30-2010, 10:05 PM
lesterl's Avatar
lesterl lesterl is offline
Re: many problems with 2000 venture
I would get a repair manual with good wiring diagrams and start looking at grounds....
1997 Chevrolet Venture SFI 3.4l Auto 249k
2006 Chevrolet Malibu Maxx SFI 3.5l Auto 81k
http://www.s10forum.com/forum/attach...nsor-chart.gif
Old 05-31-2010, 01:57 AM
do they make chilten manuals anymore thats the kind i used to get haynes didnt have very good diagrams. you think all these problems are caused by bad grounds?
Old 06-01-2010, 12:39 PM
dewaynep dewaynep is offline
Have these problems been creeping up on you one at a time or did this all happen at once?
Old 06-01-2010, 01:45 PM
been creeping up on me slowly
Old 06-01-2010, 01:48 PM
If that's the case then I would follow lesterl's advice. A good wiring diagram is priceless in these situations, all except for the wipers parking in the up position. That's a malfunction in the parking mechanism of the wiper motor that usually is cured by lubrication (if you do a forum search you will likely find the answer to that question).
Old 06-01-2010, 01:49 PM
DIY Repair Manuals DIY Repair Manuals is offline
The Chilton's manual is no good. Get the factory service manual, it has all the wiring diagrams and ground points.
Old 06-01-2010, 04:31 PM
lesterl's Avatar
Try www.autozone.com, they are free and a good place to start, I suspect that DIY R M's is SPAM, so I would suspect he is trying to sell something either now or later.....
Old 06-01-2010, 08:17 PM
thank you everyone
Old 06-09-2010, 09:19 PM
fanta2 fanta2 is offline
GM Fan, but waning a bit.
shanestieber - had many of these problems with my 99.
windows started not rowing up and down all the time now they dont at all - check switches, I replaced driver's side window motor.
electronic door locks only lock the vehical not unlock them - wires under passenger side carpet are probably corroded. Search this forum you'll find it's an easy fix!
gas gauge only works when i have the car sitting still and nothing moving - sender is probably bad; fingers are probably corroded. Search this forum, there's a GM additive that actually helps.
air bag light on i have no idea what caused it - probably a sensor issue. Good luck!
Old 06-11-2010, 03:45 AM
tgank you very much this is most helpful on my next days of i will try these i was also told that the headlight switch could be bad causing these problems have you heard of this
