Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 05-30-2010, 12:18 AM
DaChevyClassic DaChevyClassic is offline
stiff accelerate
94 chevy caprice...lt1 motor....i have stiff accelerate...i got a new accelerate cable...but itz still stiff...help me out whats da problem???
Old 05-30-2010, 11:50 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: stiff accelerate
Does the throttle hang up (stick) at all?
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 05-31-2010, 01:46 PM
No. It don't hang up...It just stiff...
Old 05-31-2010, 10:40 PM
j cAT j cAT is offline
with the cable disconnected from the throttle body is it stiff ?
If not then with the cable off remove the air inlet ducting and using throttle body cleaner [NOT CARB CLEANER] , and using a tooth brush , give the throttle body / plate a good cleaning ..do this when cold...do not use too much cleaner...allow to dry before starting...keep throttle plate open so excess cleaner will evaporate faster..
throttle body needs cleaning about 20,ooomi...usually you get sticking ..
