i have a 84 s-10 i went from and automatic to a standard trans now i have an vibration when i start eng need help what cause vibration is the eng internally balanced any help would i would be gratfull
Re: changed from automatic trans to stand
Will cause a engine shake. Did you use right flywheel for year make and model and engine and a good new clutch and pressure plate? Describe your vibration? Is it with transmission in neutral or in gear with clutch pedal down or up? Engine at idle or speed-ed up and what RPM? Or just on the road?
It is out of gear the engine runs smooth with when it was automatic its an 84 the trans came out of same year and model THE ONLY DEFERENCE WAS THE OIL PAN ON THE ENGINE if i leave it like it is it will beat the bearing out CAN I UNBOLT FLYWHEEL AND TURN IT TO ANOTHER HOLE
Is it more at certain RPM? Shake in gear or out of gear> Out of gear clutch down or up does it shake?
it vibrates at idle and gets worse when i give it the gas. when out of gear
Did you install new clutch and pressure plate?
no we used the same stuff all of it it was all good
If everything was good then it should not be shaking.
probably need to resurface-balance flywheel
