Go Back   Automotive Forums Car Chat > Volvo > S80
Old 05-29-2010, 05:20 PM
bouseman bouseman is offline
power sunroof not working
2000 s80 the sunroof was working fine, then went to open and nothing happened. It does not make any sound when I try to open. My regular mechanic will not even investigate. Any suggestions? I have checked fuses and they are fine. thanks
Old 08-13-2010, 11:20 AM
Doniku Doniku is offline
Re: power sunroof not working
hi you must take the sunroof off the car and than open the engine of the sunroof because it may be blocked and than you take the engine of the sunroof and go to scrapyard where you can find the engine of sunroof and than put it in the function it will work also controle the old engine off the sunroof in te batery of car by lining the two pols in batery have a good luck bye
Old 12-03-2010, 04:56 PM
Detrinova Detrinova is offline
a lot of the newer volvo cars have sunroof modules that are connected to your siren module. check your siren out and see if it works if not that may be your cause. I haven't been at volvo that long so i havent seen that many older ones like yours yet to know if yours is like that though.
Old 12-03-2010, 07:32 PM
danielsatur danielsatur is offline
Don't forget to check the relay!
Old 12-15-2011, 09:53 PM
workingout's Avatar
workingout workingout is offline
on the 99's, the sunroof will not work if the voltage output of the alternator is to low. this will also affect the power door locks. the voltage will be to low to run optional systems yet still high enough to not set off the low voltage indicator warning light.
Get a bigger hammer.
My Johnston Rod got caught in the Pittman Arm
