Go Back   Automotive Forums Car Chat > Dodge > Durango
Old 05-29-2010, 03:55 PM
deanbar2009 deanbar2009 is offline
2002 durango starter removal
ok i am haveing trouble removeing the upper bolt on a 2002 durango starter there is barely enough room to get a wrench on the bolt then not enough to wrench it cant get a soclet on it because the factory starter as a bump out right in front of the bolt that inders clearance to the bolt i ahve tried every which way and still no luck can some one tell me what i need to do on this
Old 06-04-2010, 08:29 PM
rhandwor rhandwor is offline
Re: 2002 durango starter removal
http://www.zdmak.com/ Search MK-1012E
http://www.tooltopia.com/ Search SK33351
Some parts stores sell on you can put any size 3/8 socket on it for axcess. I've had to use two before.
If you break it loose with an obstruction wrench try 1/4 drive socket.
Old 07-20-2010, 07:16 AM
mikesheldon mikesheldon is offline
dont be scared, just grab the front and backing (easier to do with your nails), and pull out the backing- there is an indentation in the earing so the backing wont fall out so dont be afraid to pull it- dont worry, it is not stuck
good luck!
Used semi trucks
