Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 05-29-2010, 01:10 PM
dougand3 dougand3 is offline
94 Camry Wagon - Hatchdoor latch broken
Can't open the hatchdoor. The gray rod from the handle pulls on a brass plate within the latch assembly but he brass plate has no resistance - it seems detached from it's mechanism to unlock. Can't get to bolt heads to detach door latch assembly cause locked. Any ideas to open door? Thanks. Doug
83 MB 300SD - 305k miles
93 Escort 1.9L LX Wagon - 220k miles
95 Isuzu 2.3L P'up - 230k miles
Old 05-30-2010, 09:45 AM
Re: 94 Camry Wagon - Hatchdoor latch broken
Not a great pic but the gray linkage rod inserts in the hole on brass plate. The brass plate rotates CW (downward) to open the latch. Brass plate is very loose - it's not engaging anything. Another thing is a wire with 1 red/1 white leads going into latch mechanism. So, I'm not sure if pulling on handle mechanically opens latch or activates an electrical actuator to open latch.
